AC belt will not stop squeaking.
Ok my AC belt is freaking pissing me off. I have replaced the tensioner 3 times with a Gates one from oriellys. I have bought the cheap and expensive belt from oreillys. The ac belt makes noise with the AC turned on and turned off. I just dont know what to replace next.
I have thought about replacing the tensioner with an AC Delco or Goodyear and buying the gatorback belt.
If i spray the belt with a little water or wd40 it stops for a breif minute.
Anyone else have an idea???
I dont think the pulley is misaligned but the main belt does not do it just the ac belt. I have run the truck with each only. The main belt no noise by itself. The ac belt LOTS of noise by itself.
Quick question, the ac tensioner is new, actually i have 2 new ones sitting here. Both make the same amount of noise. I can deflect the AC tensioner fully by pressing down on the belt. I cant do that with the main belt. I wonder if the tensioner is just plain weak?? Perhaps i should try a different brand.
I had this problem when I first put the 408 in my truck. It was annoying as hell. What fixed mine was pretty stupid but I saturated the belt, pulley, tensioner, ect in belt dressing and kept the engine between 4000-6000rpm for a bit. Then went back and saturated and repeated.
Stupid but after two pulleys and tensioners I didn't know what else to do.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
