accuseal clamp users
So I'm trying to get my Y pipe to seal up my collectors. I threw on some 3" accuseals and clamped them down as hard as my little ratchet could get em. Yet I still got little pufts of exhaust coming out. Where should I have the clamp placed for best seal? Should they be 100% over the OD pipe (which is where I have them now) or should I put it so that the middle of the clamp is right over the edge of the OD pipe? Also, would o2 safe RTV helped if I jammed some of that in between the pipes?
I wouldn't use ANY silicone near the O2 sensors, even slighty downstream. I use Band clamps and wrap a couple of turns of aluminum foil around the slip joint then tighten them down hard.
There is no such thing as "sensor safe" rtv, at 80.00 bucks apiece for O2's it's not worth it. Walker has a new band clamp forgot the name but it's a nice one .
Hey, thanks a TON for the tip on the aluminum foil! I bought a Torctite 3" band clamp, but wrapped the joint with a couple layers of foil and then torqued down the clamp. Leak gone. Unfortunately, I needed 2 more clamps and NAPA had no more so I had to order them off ebay. The way the Pacesetters work though with the O2 bung, a band clamp will not work on the passenger header So I clamped down the Accuseal as tight as it will go and I don't feel any leak when it's idleing but I don't know if this means it doesn't leak under throttle.
Superman09
09-25-2015 05:55 AM
