Aem Cai
Aem Cai
I installed a AEM intake on my truck yesterday, easy install. They now have a new filter that does not require oil in the filter, its totally dry, and is still re-useable. I took it for a run, and in addition to some extra noise at WOT, the mid range seems a bit stronger. Its too early to see if it helps fuel economy any, but I've been averageing 18 since I got the truck almost a year ago, so I'll update this in a bit with new numbers, if they are different. Like I said, it went in real easy, AEM really did their homework on this, everything fell into place like it was a factory piece
go to aempower.com they have a big deal about it . its in the truckin mags to . its suppose to outflow oiled ones also . be honest my buddys 00 5.3 with a oil brute force and fans . compared to my 05 dryflow brute force and eletric fans his intake is louder why is that ?
[IMG][/IMG]
The kit came with a cleaning solution- done in a water filled bucket. It's dark but I'll try to snag a pic for ya...
As for the noise, you can def. hear it, I also have a FM Super 40 exhaust system on as well (crap I know, but it sounds good enough to turn heads )
Edit- In the pic it looks like the filter is hitting the fender, its not. The filter goes under it. And no the coolant isnt low either
*EDIT* I see you got the pic! Thanks! Nice looking unit
