AEM to EGR
FormerVendor
You will want to use the brown wire at the EGR harness which is the EGR pintle position reference wire running to the PCM which if I remember correctly is pin 55 on the blue PCM connector. This is the 0-5 volt reference that you will need and then you will need to log PID 2811 in the main table which is EGR Position (Volts) and then of course setting up the histograms, etc..... which is pretty easy
