Ahhhh, fuel pressure issue
Let me get my tunes straightened out and I'll test out more boost.
Ben, I haven't noticed a drop in boost up high, although I haven't really done many high rpm bursts with it in the last day. To be honest, it looks like it gains about .5 psi as it gets to the 6000 rpm mark.
Originally Posted by BigTex
OK, is it better to have 20* timing and 7psi, or have to pull timing back some and go for 9 psi?
Check your pm's bigtex.
I got your PM and I'll take a look. You really need to be able to do your own tuning. Mail order stuff should be better than a hypertech, but it won't give you near the benefits of being able to tune yourself as needed.
You know what? i think your right!
Tribe Shaman
for my vacuum / boost gauge I hooked it up to the vacuum line off of the intake that went to the fuel rail regulator.
for my boost gauge I taped the 90 on the pressure side of the bypass value next to the blower.
my fuel gauge is hooked up to the shredder value. i removed the value from the inside, twisted a loop in the line, filed it with oil, set the gauge up inside the cab in the piller pod
1 tells me how much boost the blower makes
2 tell me how much boost pressure is inside my motor
3 tells me my fuel pressure during boost when my fmu kicks in
Originally Posted by vortec327
Holy cow 20* im lucky to see 10-12* at 8 psi. Hmmm i think my tune needs a revamp
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
