air compressor noise behind motor
Old 04-29-2006 | 10:34 AM
mrb04's Avatar
Default air compressor noise behind motor
2005 Yukon built motor trans turbo ext sounds like a air compressor pumping up behind the motor maybe on frame rail or in trans. not a real loud noise but very annoying. maybe some kind of pump. comes and goes, almost never on when you first start it. anybody with any ideas thanks
Old 04-29-2006 | 11:12 AM
Flyer's Avatar
Might be the vacuum booster on the brake booster. Does it have a big cam in it?
Old 04-29-2006 | 02:28 PM
mrb04's Avatar
zo6 cam and 319 heads forged pistons rods and bored to 5.7
Old 04-30-2006 | 12:22 PM
03lowriderss's Avatar
i think that i know the sound that your talking about is it happening when you are just hardly on the gas at highway speeds?
Old 04-30-2006 | 06:26 PM
mrb04's Avatar
it will do it at any time does not change when rps do and will do it in park. any ideas thanks
Old 04-30-2006 | 06:47 PM
TurboGibbs's Avatar
Sounds to me like exhaust hitting the body or frame somewhere.
Old 05-01-2006 | 01:02 AM
Full_Pull6.0HD's Avatar
Don't those have a air suspension setup kinda deal. (that sounds intelligent) My mother has a 2002 Denali and it does something like you explained. Yeah actually now I see you say it does it in park. I am quite confident that is what you are hearing.
Old 05-01-2006 | 01:07 AM
TXsilverado's Avatar
i have pacesetter longtubes, and i get a sort of "aircompresssor" tick when it idles. no gasket leaks, and it does it with the exhaust cutout or closed through 2 mufflers. i think it just boils down to more mods, more noises.
then again, you might be hearing the infamous slapping piston. no worries there either. just anoying as hell!
Old 05-01-2006 | 04:09 PM
Yelo's Avatar
Like Full_Pull6.0HD said: I'm betting you're hearing the air compressor for the rear air-suspension.......
Old 05-01-2006 | 10:49 PM
mrb04's Avatar
this yukon does not have auto ride or headers any other ideas thanks
TXsilverado
11-26-2015 11:54 AM
TX Tahoe Z71
09-01-2015 10:11 PM
V-seriesTech
07-28-2015 01:31 PM
rojeho
07-12-2015 07:10 PM
GRRR65GTO
07-10-2015 09:27 PM
