air intake questions
#41
I got this thing to use in my Samurai.. but its been staying in my truck ha..
ScanGaugeII : Linear Logic - Home of the ScanGauge
has all the readouts you need. and you can check/clear DTCs also.
#43
The IATs that I posted above are from TPI & V6 82-92 F-bodies. I have no clue what the LS/98+V6 uses for IATS. The IAT is cheap enough at Autozone/NAPA/where ever so we just buy new ones, not used.
To put it in my air intake tubing, I bought the IAT then went over to Lowe's with it to find a nut that fit it. When I drilled the hole I made it just the size of the IAT shaft, not the threads themselves, so I was actually able the thread my IAT into the plastic itself. I can't recall if I put the nut on the inside as insurance to hold it or not but I know I was concerned that it could come loose & get sucked in through the throttle body.
Whats the PN for the IAT like you have pictured above?
#44
Remember though.....I only showed it because of what I learned with my GTA. Whether or not the IAT would work for our trucks, I have no idea.
Duralast SU107 (alternate # CS-8) On Autozone.com.....
Duralast/Air Charge Temperature Sensor (SU107) | 1991 Chevrolet Camaro RS 6 Cylinders T 3.1L MFI OHV | AutoZone.com
Directly from the article.....
The main reason is so that the ECM sees the correct air temperature. Three causes why it doesn't:
1) the Intake Air Temperature (or Manifold Air Temperature) sensor is located in the intake plenum, on its underside, so it is heatsoaked from all the hot surrounding metal.
2) the stock Intake Air Temperature sensor is nothing but a CTS (Coolant Temperature Sensor) which is a big metal piece with threads and a connector. So in fact, this big piece of metal has NO WAY of measuring the temperature of the air at the big honking metal tip, instead it measures the temperature of the hot manifold.
3) the intake manifold is full of what? Air? Well, only at WOT. Otherwise (most of the time), there is a lot of vaccum in the manifold (i.e. lack of air). So WHAT air temperature can the sensor measure anyway?
What
This picture shows the stock TPI IAT sensor (on the left) vs the V6 IAT sensor (on the right).
The stock TPI IAT sensor is the same as the CTS sensor and thus measures reliably the temperature of whatever mass it is screwed into. Like the hot intake plenum.
Whereas the V6 IAT sensor has a protruding plastic sleeve with screens and a sensor pellet placed in the screened openings, to measure the temperature of the airflow through the screens.
There is no electrical difference in these two sensors whatsoever, their readings are identical, they are completely interchangeable when it comes to their electrical specs and plumbing.
Oh, I forgot a minor detail: their plugs differ very slightly. But if you shave two tabs on the sides of the connector (with a knife or a file), it will plug in with no problems.
Where
The stock TPI IAT sensor is located on the bottom of the upper intake plenum, towards the back. It is facing the lower intake manifold.
My car came with the filter intake runners that supposedly go on a V6 engine and that have a 3/8" NPT hole in the side. Specifically for the IAT. So this is the place where I installed the new IAT.
How
The stock TPI IAT sensor is in a not very accessible location. It is hard to reach but You might be able to pull the plug off with a thin long screwdriver and some needlenose pliers. Otherwise, take off the upper intake plenum to access the IAT and connector.
Trace the wireloom behind the passenger valve cover and disconnect it from the black two-prong connector (C121). Splice into the harness and extend it so that it can reach to the new sensor location.
Purchase (or obtain through other means available to you) an IAT sensor for a V6 MPFI engine and make sure it's the right one.
(you can also use the IAT sensor from a TBI engine, it has same electrical characteristics and connector)
(when locating the sensor, be aware that it might be called ACT - Air Charge Temperature, which is more of a Ford term but some stores use it for the Chevy sensor anyway)
Shave the two tabs on the sides of the IAT connector (with a knife or a file) and make sure that it will plug into the new IAT sensor.
Install the IAT sensor into its new location (in the air filter runners or elsewhere).
Now just run the extended wire safely so that it doesn't get caught on any moving parts.
Disconnect the battery for several minutes so that the computer can relearn how to adjust the mixture with this new reading.
Results
Many people are VERY skeptical about this change and say that it does not make much of a difference.
However, from my practical experiment using datalogging software, I can say without exaggeration that I've seen a 35-degree (F) CONSTANT difference in the intake air temperature measurements.
With the stock TPI IAT (heatsoaked CTS part), the computer saw 132 degrees in the intake on a 95 degree night. That measurement was performed on the highway, i.e. with lots of air flowing through the engine compartment. Stopped at idle, the temperature reading was even higher.
With the relocated TBI IAT sensor, the computer saw 97 degrees on the SAME night, with 95 degrees outside. Again, this measurement was performed on the highway but the reading did not increase much at lower speeds or at idle.
So there, it's not a myth and if done properly, the computer will see the REAL air temperature. And especially in Texas, that makes a world of difference.
What
Where
How
Results
#47
im planning on it lol, ive been thinking about ditching my WB for one but in reality id like to keep that too...just gotta save for a bigger pillar pod and the coin for that aeroforce. and hopefully ill have some results to post by tonight, did a side job last night so got a little bit of coin to play with hopefully this heat soak bs goes away once and for all
#48
little off topic but i picked up a harness and 3 sensors yesterday from the boneyard, two long ones and one short one. idk which would work better, theyre all the plastic ones with the cage around it. and most importantly before i go depinning the wires in the maf harness am i gonna pull any codes or have to be retuned for this little difference? as of a month ago my tuner is fired...figured its something i should probably ask before running some wiring
#49
Just dont crank or turn the key on when you have the wires un plugged.
Be good to go after that!
a before and after reading would be nice too with the scan gauge to actaully see whats goin on.
#50
damn lol i think i may have done that with the radio on the other night...guess ill do a pcm reset then. truck did feel a little funny today thinking about it. but i did notice a difference in less heat soak, didnt help as much as i thought it would but last night with the cool 65 degree air she pulled HARD and had no problem destroying the 35s from a roll. not to jack my own thread but i think when i blew the converter up the last time they restalled it. noticed today under heavy load in 3rd she flashed to 4100-4200
