All ATI onwers.
Old 07-27-2003, 12:49 AM
StupidFast's Avatar
Default All ATI onwers.
I recently purchased a new intercooler and 3.6in pulley for my Procharger. I installed them one at a time. First the intercooler and then the pulley.
My intercooler worked fine and actually picked up a lb. of boost. It is a little big so I had to cut my front skirt to have it fit. I don't know how to post pictures or links. There is one the same size on Ebay but it does not have the mounting tabs.
After I installed my pulley and tried to tune it, I found that the belt was slipping big time. I went to the auto parts store and bought another belt. It slipped. Went back a purchased another belt and some STP belt dressing. It slips and finally catchs. I still only make 13lbs of boost after it grabs, it is still slipping.
Intercooler =
15lb. pulley =
Just thought I would let everyone in on my experiences. I will try to take some pictures and email them to someone to post.
I will probably install the 12lb. pulley and a 50 shot. I will drive around this pulley for awhile and see if it gets better.
Old 07-27-2003, 12:53 AM
Banned
Default Re: All ATI onwers.
Johnathan, i'll help you post the pics one day if you have them on your computer or whatever.
Old 07-27-2003, 07:00 AM
GMC SKI's Avatar
Can we use the MMS larger Crank pulley ?
I don't even know if it's 8 rib or not
you can try that route or what I'm going to do is get my blower braket beefed up the metal they use is pretty thin and tends to flex i think that the Flexing has something to so with the amount of rubber dust i have going on
Also you should conside Getting an ultra grip pulley from riechard racing.I heard there pullies work great .Otherwise we need an 8 rib setup to be made up
jim
Old 07-27-2003, 10:11 AM
tbyrne's Avatar
I've found that the Goodyear Gaterback belts work really good. I use these on my supercharged Grand Prix and Suburban. I used to burn up regular belts with the smallest pulley on the Suburban. It works fine with the Gaterback. This would be a quick, less expensive option to try first.
Old 07-27-2003, 10:58 AM
GMC SKI's Avatar
I been there with the Goodyear belts them seem to work better than most other belts
I found that the goodyear GB belt and some locktite belt dressing works really good for a short period of time..sure does make a mess though stick rubber all over the place
Old 07-27-2003, 02:08 PM
StupidFast's Avatar
The Gooyear belt is what worked the best. I think that I will reinstall the 12lb pulley and shoot some N2O. I ran pretty good with 12lbs. The new intercooler worked really well.
I will look into the Riechard Racing pulley. Do you have a link?
Old 07-27-2003, 08:09 PM
GMC SKI's Avatar
http://www.reichardracing.com/
They are pretty cool guys i talked to them abit about the slip problems
Old 07-28-2003, 09:26 PM
StupidFast's Avatar
go to "truck lounge" for pics. Also, does anyone have an FMU for sell?
Old 07-28-2003, 10:06 PM
GMC SKI's Avatar
I got my Old FMU i could sell you
shoot me any email or something
Why are you going with the FMU again ?
Old 07-28-2003, 10:34 PM
Banned
what the hell is FMU?
Quick Reply: All ATI onwers.
