Are all truck coils the same??
Old 03-05-2005, 10:40 PM
jcfreak's Avatar
Originally Posted by therock
There is a GM TSB about #7 misfiring.
What does it say is causing it?
Old 03-06-2005, 05:48 AM
therock's Avatar
Default IT Didn't Say
And I am not sure if it effects your year model. I am just about sure it is a pcm problem.
Old 03-06-2005, 06:50 AM
jcfreak's Avatar
I've had 3 different tunes in it and it still did it.
Old 03-06-2005, 02:01 PM
I think the injectors get clogged from the fuel rail causing a misfire. Did you have the crank relearned after installing the PCM's
Also, I heard that the coils won't interchange (different wire connectors). I've never tryed it personally though so I don't know for sure if that is true
Old 03-06-2005, 08:39 PM
jcfreak's Avatar
Yep. I've done all that. It has new injectors and I have had the crank relearn done.
Old 03-06-2005, 09:39 PM
Do you still have your stock cats (not sure what pipes get replaced with the STS kit), you might want to have a back pressure test done. I've heard of a few trucks that had chronic misfires due to plugged cats. Some affected all the cylinders, others 1 or 2 only. good luck
Old 03-06-2005, 10:50 PM
LIL SS's Avatar
Open a new thread please..
signguy62
09-20-2015 02:05 PM
GM1697
09-11-2015 10:19 PM
wrb002
08-31-2015 12:00 PM
Suburban2500
07-19-2015 04:50 PM
black6spdz
07-16-2015 01:32 AM
Quick Reply: Are all truck coils the same??
