All Vortech, ATI and Magnuson superchargers on sale
We are offering discounts on all Vortech, ATI and Magnuson superchargers that we carry. A quick rundown of the gains from each system is -
Vortech - about 100-110hp (not intercooled)
The Vortech supercharging system for the 4.8/ 5.3/6.0 GM light truck will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower to 391 and torque to 420 ft/lbs (5.3 Engines) to help you pull you, your passengers and your toys over the hill or around the corner.
7 PSIG
Includes V-2 SQ S-Trim supercharger
Satin (010SQ) or Polish (018SQ) finish
Hand-held programmer controls ignition timing and fuel enrichment
OEM style cast aluminum supercharger mounting bracket
Cast aluminum discharge tube with Bosch compressor bypass valve
Molded inlet duct retains stock air box and MAF locations
Oil drain, oil feed, and air intake assemblies
ATI (P-1SC) - about 115-125hp (intercooled)
Intercooled ProCharger supercharger systems enable your truck or sport utility to deliver unparalleled performance without sacrificing daily drivability or gas mileage. In fact, unlike inefficient positive displacement superchargers, in most towing applications your gas mileage may actually increase slightly thanks to the superior efficiency of the P-1SC ProCharger. Stock or modified, for towing, daily driving, or racing, Intercooled ProCharger systems deliver far more performance with far greater engine reliability than any other supercharger system or power adder such as nitrous oxide. System produces 8-9# of boost and comes with a 2 core intercooler to show you a 60-65% increase in horsepower.
Magnuson (Radix) - about 130+hp (intercooled)
Magnuson Products, Inc. , manufacturer of superchargers and supercharger systems for foreign and domestic vehicles is pleased to announce the availability of the newly designed, intercooled supercharger system for the 4.8L, 5.3L and the 6.0L Gen. 3 truck engines, including the new H2.
This all-new intercooled supercharger system utilizes the Magna Charger MP112 supercharger with internal bypass valve. Torque and horsepower increases are improved 63%-125% from 2,700 rpm to 5,500 rpm, giving more "power under the curve" than any other supercharger system available. This translates into a 130+hp increase to your rear wheels!
Intercooled systems are complete with all components necessary for installation. Included in the kit is the patented intake manifold (replacing the factory nylon manifold), intercooler core, coolant circulation pump, heat exchanger and all necessary hardware to complete the entire installation.
Other components include new fuel injectors, fuel rails, factory "push lock connectors" and regulator adapter. Computer programmer communicates with the factory ECU for proper calibration of the supercharger system. Transmission shift points, line pressures and converter strategies are optimized for use with the increase in torque and horsepower. Extended power train warranty is available for customer piece of mind.
These numbers can vary depending on other mods that are done to the vehicle along with your altitude and tuning. Just e-mail tbyrne@tbyrne.com for pricing.
7 PSIG
Re: All Vortech, ATI and Magnuson superchargers on sale
Vortech has recently added a few new part numbers to cover most years of the 5.3 and 6.0.
ATI now has two kits available. One for the 4.8 and 5.3 motor. This will make 8-9# of boost while the kit for the 6.0 will product 7-8# of boost. There is also a 3 core intercooler upgrade that replaces the standard two core. This one is rated up to 750hp. The complete kit with 3 core intercooler is available for just over $3500.
Superman09
09-25-2015 05:55 AM
TrickTurbo
09-23-2015 08:41 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
