AMW catch can oil - after 1 week [pic]
#24
I think I should try this. The reason being is that on average I lose about a little less that a quart between oil changes. It might be buring up but it also might be going somewhere else. You guys think this is a good idea to try it.
#25
PT's Slowest Truck
Yea, I'm N/A, and I couldn't believe how much oil was being sucked up through the PVC...then I thought about the inside of my intake, and my combustion chambers, and my valves...aaarrrgghhh! Did a seafoam induction service right after the installation of the can.
#26
single digit dreamer
i think this is a good idea for everyone. i have had a few motors apart and the amount of oil in the intake is prety sick, there is no way it can be a good thing.
on my set up the pcv goes right in front of the turbo. that means all that oil goes thru the intercooler. i bet there is a significant drop in efficency with an oil coated intercooler.
i have a question. i have found baked on carbon on the pistons and intake ports and back of the throttle blade. is that oil related or just something that happens even without the oil?
#27
I am not to sure on the pistons and the intake ports, but from what I understand behind the TB plate is all the buildup from the EGR.
I did clean my TB couple of weekends ago and I stuck my finger in the intake and there was a nice thin even coat of oil smudge
#28
So AMW doesnt use a filter?? What if you used a slightly larger coalesing filter than the one everyone is using for the homemade ones and just wrapped a piece of stainles mesh screen where the filter goes and somemething like a filter element laying on the bottom to absorb the oil so it can't bypass the can??? I have a larger one, I may have to do some experimenting.
#30
PT's Slowest Truck
