Another Cam question SLP 51013
From slponline.com
My 5.3 has only intake and exhuast changed. Plus EFI Live.
PHP Code:
For the enthusiast who wants a matched camshaft package, SLP offers this complete cam kit. Through extensive dyno and track testing, our engineers have developed a package that provides maximum horsepower and a moderately aggressive idle in LS1/Ls2/LS6, 5.3L, or 6.0L applications. Each kit includes a camshaft, matching valve springs, titanium retainers, and keepers. This "package" approach takes the guesswork out of valvetrain assembly, letting you focus on the fun part-making power! Not legal for use on pollution-controlled motor vehicles.
NOTE: PCM reprogramming strongly recommended. Use SLP's Valve Spring Compressor Tool Set (part #53306) for in-car installations.
Camshaft Specs: Valve Lift Duration@.050
in: .576" 234º
ex: .571" 228º
Centerline - 112º
Lobe Separation - 113º
thats a bit big for a 5.3, you would need a fairly large stall for that cam..to get the full benefits of a cam you need some long tube headers, 4.10 gears and you was to run a cam with that much duration you would need a 3600 rpm stall, you might want to stick to a 220-224 duration cam with the supporting mods and 3000 stall..do some research on what setups people are runnin..what kind of truck do you got?
1999 rc step 2500 stall
stock manifolds feeding 3.5in x 18in collector, no cats, 3in mandrel bent to the 50 series Flowmaster at the bumper. The collector actually gives it a nice ring
bbowerman
07-26-2015 10:57 PM
