Another cam thread.
#31
same thing mr. fuso... I may swap to 243 heads, but at this time no gear or stall.
Tootall, explain efficient and stock heads with the 220 please. Interested in more info.
#32
OR get a custom spec cam from Pat G if you don't want to search
5.3's with ported heads and a FAST intake did really well with cams in the 230s range. . . . again, you'll have to search if you want some more posted results
#33
There is no way a 220 intake will be worth a darn with a stock stall. The absolute max intake I'd run with a stock stall would be a ~214 with any amount of lift. When people talk they're usually talking peak HP numbers, which seems cool in conversation but means nothing getting you down a strip or the road. The real game is to get a nice wide powerband so that whenever you punch it, you have power. A 22x duration with any amount of lift will start your powerband over ~2300rpm even with an advance. You might get away with a TB stall and a 220 or 224, but you'd want a 4* advance. Tuning can hide a lot of these issues which is why it's hard to find a telling dyno.
Adding just 243/799 heads, even decked .030, will hurt your low-end numbers. My goal for a big-heavy crew cab 4x4 DD was always to widen my powerband and maximize torque and I love my combo. Adding a LS6 cam will give you a nice HP gain too, but I think you'll hate the turd you created.
#34
#35
I understand what you guys are saying. I'm not looking for a verter because I do still tow with my truck, and many times it's at max capcaity.
Do you think for the average joe with an otherwise stock 5.3, that a cam and headers will be noticeable as far as power gain? so right now I'm looking at a 210 or 212/218 as my best bet with a stock converter. What about lift and lsa. I've heard lower lsa moves the powerband lower, like a 112. So how does advance affect that?
#36
#40
Nealy any place will do custom grinds. I also kind of disagree with the notion that a lower LSA will provide more low end torque as a general statement. What a lower LSA does is it changes the powerband from a plateau shape to a mountain shape with the peak numbers coming in lower than the "peak" of the higher LSA. If you're talking about moving the curve down to a lower RPM range uniformly, then you're talking advance. Lower LSAs also come with lower vacuum and typically higher overlap which comes with it's own emissions implications.
