Another e fan question
I have done alot of reading a research and understand 05-06 stock e fans will bolt right up to my 99 silverado 5.3 Liter as long as i have a 34" radiator, but what i cant find is where on my radiator do i measure to determine if i have a 34" radiator. If i measure just the core its 28" but if i measure from end cap to end cap its approx 34". Is there an easier way to tell if the 34" fans will fit.
Yes measure the core or look at the back of the radiator core support for the mounting holes. If your radiator uses the inner set of bolt holes you have a 28" radiator. If it uses the outer set of holes you have a 34" radiator.
RadiatorExpress (03-19-2021)
