Another Fuel Pump Thread
Old 02-04-2008, 09:12 PM
MikeGyver's Avatar
Default Another Fuel Pump Thread
I'm running out of gas. The fuel pressure starts dropping at about 4000 rpm, down to 42 psi by 5000 on a WOT run, and the AFR starts leaning out at 4000. Full tank. I installed a new stock pump/bucket assy. last summer. With my new engine, I put in a new filter, and a brand new MagnaFuel 4301 inline. I replaced another 4301, it somehow got noisy during the motor job.
Does anybody have a similar set-up? I can't believe that the stock pump or bucket is acting as a restriction.
Old 02-04-2008, 11:59 PM
Hawk179's Avatar
Its a pressure problem. Put a Bosch 044 pump inline off your main line and you should be fine.
Rick
Old 02-05-2008, 12:18 AM
MikeGyver's Avatar
Are you saying the MagnaFuel is a P.O.S.?
Old 02-05-2008, 10:13 AM
Hawk179's Avatar
no, just sounds like its not working for you.
Have you tried just a solid intank 420 pump yet? Thats what I run.
Rick
Hawk179's Avatar
Also, couple things could be happening.
What gauge are you using for fuel pressure?
At what MAF Hrtz value are you dropping AFR?
rick
Old 02-05-2008, 10:51 AM
MikeGyver's Avatar
I'm using a Johnson Controls P399AAC-1C. It has the same characteristics as the Autometer, it was just cheaper for me.
I'm running 2-bar SD, pressure starts dropping at 150 kPa.
Old 02-05-2008, 11:23 AM
05crew's Avatar
walbro 255 and ride!!
Old 02-05-2008, 05:27 PM
MikeGyver's Avatar
What is a 420 pump?
Old 02-05-2008, 10:54 PM
MikeGyver's Avatar
Are there known issues with the MagnaFuel inline pump that claims to support 1000 HP that are unknown to me?
Old 02-05-2008, 11:36 PM
Hawk179's Avatar
What is a 420 pump?
Bosch
Quick Reply: Another Fuel Pump Thread
