Another Fuel Pump Thread
Rick
I appreciate your help Rick,
but the only thing that you said before was to get a Bosch pump. Based on that and everyone else's replies, I went ahead and ordered a Walbro 255 in-tank kit. Is there a problem with the stock wiring not supplying enough voltage to the pump? Can I just power the pump with a relay that the stock pump wires energize, and then run a fat wire from the relay to the pump? Thanks.
Originally Posted by Rick@Synergy
...You need to look at all the things I said before...
I appreciate your help Rick, but the only thing that you said before was to get a Bosch pump. Based on that and everyone else's replies, I went ahead and ordered a Walbro 255 in-tank kit. Is there a problem with the stock wiring not supplying enough voltage to the pump? Can I just power the pump with a relay that the stock pump wires energize, and then run a fat wire from the relay to the pump? Thanks.
Rick
Texas Speed and Performance (Do I get a partial refund now, Brian?). The wiring is stock still from the tank to the fusebox, I have no fuel pressure drop whatsoever now (still running the MagnaFuel inline). The pigtail that they sent with the kit doesn't plug into the stock plug, I removed both plugs and butt-spliced it. That is probably what was intended, the instructions don't really apply to trucks. All of the information I needed to install it is on this forum. They sent a piece of fuel line, I didn't need it. I cut the very end off of the stock plastic line and hose clamped it to the pump.
slowlsx
08-13-2015 08:28 PM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
