any cheaper options for the victor jr throttle bodies?
the edelbrock 3878 4150 4 barrel t/b is to pricey for me and i cant do the fly by wire on my 99 pcm
has anyone created an option any cheaper yet?
-erik
-erik
i purchased a shortblock and heads and a vic jr. for my budget build
so i dont have a t/b
stock 4.8/5.3's and 6.0's are going to be to small for the rpm's i want to turn with it
-erik
-erik
realistically i think a t/b setup shouldent cost much over 250$ or so, i'd be within my budget if i can do it for that
i think i'm going to have to hit up junkyards or fab a dual stock t/b setup up i will really only need on tps and one iac functioning the others can be dummys or blanked off
You can take an early 80's 4 barrel carb (from a Camaro/TA, or anything that had electronic control for the timing/etc.), and dismantle it to use as a throttle body. It already should have a 0-5V TPS on it, so all you would need would be a wiring diagram and to remove the choke tower and fuel venturies.
smokeshow
08-23-2015 08:23 PM
Blackrat48
07-08-2015 05:28 PM
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
