Any Diablosport Users here?
Originally Posted by Boosted
According to Diablosport the end user can tune the tq mgmnt. See below:
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Disable P0430 and P0430 codes
Adjust COT enable temperature
Multiple Misfire P0300 adjustement
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable
Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
Rev Limiters
RPM Shift Points
Shift Timing
Shift Pressure
Injector Adjustment
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
AIR code disable
Jim
I know mine doesn't have all those options. My fuel and timing adjustment is for WOT only. I don't have idle adjustment, and everything you listed from TM down. Mine is not the new model which has a lot more stuff on it but I would check to make sure the new ones have all those options for your truck.
Superman09
09-25-2015 05:55 AM
