any reason to buy roller tip rockers
arent the stocker a stamped steel body with roller tips already?
no gains from doing the swap. you would most likely have to run a valve cover spacer if you swapped also, as most aftermarket full roller rockers are taller than stockers, and wont clear the valve covers.
