Any suggestions on good water pump gasket maker?
So considering my waterpump was leaking from the gasket a bit, I decided to re-seal. The gasket was completely worn out, the second I started unbolting the pump, water drained out. There was 0 hold on the seal. Looks like whoever had the truck before me did some engine work as the cam cover had been opened and used a shitty seal for the pump.
I was going to us Ultra grey RTV. Is there perhaps a better sealing product to use or is this good enough?
Also, there is a cover at the back of the pump itself. Should I take that off and re-seal it as well?
I'm assuming we are working on a gen III engine here? If so just get the correct replacement GM gaskets for it. They are aluminum rubber seals and do a good job. The original orange colored seal gaskets are crap. The latest and greatest is black rubber and they work good and are cheap. I wouldn't even mess with resealing the pump. If its not leaking don't bother it. The pump will inevitably leak, they all do on a gen III. I would just put gaskets on it now and then later on when the pump leaks do it all again.
Raggedz71
07-29-2016 10:20 AM
GrooveCityZ71
08-31-2015 12:05 PM
