Any tips for changing spark plugs?
14 Second Truck Club
I'd like to put in some new spark plugs this weekend, any tips on how not to mess up? The main one I'm concerned about is the back passanger side, looks like a very tight fit. Any help is greatly appreciated!
Mine only took me about an hour to swap all of them. It was a very leisurely pace because I inspected the plugs coming out as I did them. Just be easy with your wires and don't put an excessive amount of anti-sieze on your new plugs.
It's not a bad job, all you need is a spark plug socket, one with the rubber insert is a plus, and a couple diff. length extensions, make the job easier. I used a socket with the hex end on the top of it and used a wrench to turn the socket on the back passenger plug. Take your time installing them, and not crossthread, use a little smudge of anti-seize on the plugs, and dont overtighten.
just double check the gap in the new ones before you put in. i did mine weds and found two that were wrong. plus for the rear pass side i used a 1.5 inch extension, made it very easy!!!! just my .02
Ford made sure to make it hard to change their plugs.
Jim
you think Fords are hard to change! try changing some on a 3000gt!! took me 2.5 hrs, and thats a crappy 6CYL!! i changed mine in my 2000 silverado in 45 mins and thats new wires too. and takin my time.
