Any tips for replacing a fuel pump 01 1500?
A friend at work had his fuel pump die. I told him that I would help him replace it. Is there anything I need to know or have? Any special tips that should speed the process. Where is the best place to get a pump cheap? Thanks
well i bought my factory pump two years ago from O'riley's and i THINK it was around 200 or so.
and the best way to do the pump is to remove the bed. just remove the filler neck, un-bolt the bed, its only four bolts, and slide it to the back til the top of the tank is visible.
or if you have a cherry picker, you and get some rope and tie an x using the loops in the corners of the bed and lift the bed with the cherry picker
High on diesel fumes
I dropped my tank...wasn't too difficult, but I had run the tank almost completely dry. I removed my driveshaft and was able to sit upright in there and see what I was doing while disconnecting the lines. If there's fuel in the tank though, you'd be much better off removing the bed.
InsaneDomestics
07-27-2015 02:42 PM
Mossyoakglock
07-17-2015 08:30 AM
