Anybody towing with the FAL 282 fans?
Old 08-02-2007 | 08:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Anybody towing with the FAL 282 fans?
Just want to make sure Im not going to have problems overheating with them. I have read where people have had problems towing the 05 efans, the ls1 efans and a few of the other smaller fan variants.
Old 08-03-2007 | 07:37 AM
1slow01Z71's Avatar
ttt..
Old 08-03-2007 | 12:07 PM
12secSS's Avatar
I want to know as well, very good topic.
Recently I was towing our enclosed trailer up a long hill in this summer heat, and I saw my coolant temp reach 220! I backed off of the throttle and it strated to come down, due to the fan working at speeds. I worry what would have happened had I had the E-Fans instead.
Old 08-03-2007 | 01:01 PM
TurboGibbs's Avatar
I've towed boats, cars and tractors and never had problems with my 05 efans. One thing I have kinda noticed is all 05+ have the largest radiator. It may have a factor.
Old 08-03-2007 | 04:46 PM
1slow01Z71's Avatar
Thunder550 said he had problems with his 34" radiater and 05 efans which I dont understand since thats what comes stock on the newer trucks there arent any problems.
Old 08-03-2007 | 05:14 PM
thunder550's Avatar
High on diesel fumes
I think it may have been a problem with the radiator. I have now replaced my water pump, thermostat, fan (back to clutch) and was still having problems. Swapped to a brand new OEM radiator (also flushed and switched to the regular old green coolant) and I think the problems are gone. We haven't had a nasty hot day yet and I haven't towed yet but it seems to do better. I was overheating at idle with the clutch fan If that doesn't scream "problem" I don't know what does.
The one I was running was a junk yard pull-out. I've heard that dex-cool likes to gel up or deposit crap on some of the surfaces when left to open air for an extended period of time. I don't know how long it sat open in whatever wrecked truck it came out of, and I had it open for 2 months while I did the latest motor swap. I have a feeling that I either got a bunch of junk in between the fins or that I have a lot of surface deposits inside the radiator.
Anyway, I have no plans to switch back to e-fans. I'm tired of troubleshooting, and if this fixes the problem I am not going to change it again. I don't even really notice a difference actually, and it's another set of electronics and wiring that I don't have to mess with. Peace of mind, I guess.
Old 08-04-2007 | 09:34 AM
1slow01Z71's Avatar
Main reason Im doing the swap is for gas mileage(from what I have read) and to clean up the front of the motor to show off the motor more when I finish my vic jr swap, there will be alot fo bling under the hood
Old 08-04-2007 | 08:12 PM
Scott Mills's Avatar
No problem towing with the fans, but the main power wire to the fans has been getting extremely hot and blowing fuses. I have traced the event to when my A/C condenser cycles on and off. I think my BCM is craping out.
Old 08-05-2007 | 11:32 AM
1slow01Z71's Avatar
You may have the old FAL harness the new one has larger gauge wires so they dont so hot.
calsdad
06-14-2023 11:07 PM
AdaMax
05-16-2016 11:35 PM
cheyenne383
11-13-2015 09:24 AM
CD82
10-23-2015 07:32 AM
Wrecker 426
09-30-2015 09:39 PM
Quick Reply: Anybody towing with the FAL 282 fans?
