Anyone done or seen a RCSB D-max conversion?
Old 02-13-2013 | 11:38 PM
pewterliftedz's Avatar
This would be an awesome project...
Old 02-14-2013 | 12:01 AM
BGERALD's Avatar
Matt's is an LBZ too which makes it that much better. Once he gets through building this bagger bike for his buddy ill update with the link to his build thread
Old 02-14-2013 | 07:50 AM
thunder550's Avatar
High on diesel fumes
I really like the idea of using the lighter half ton frame to keep the weight down. There's a guy on diesel place that has stuffed a d-max into a Tahoe, and I've seen it done to a half ton avalanche too, so i know it's not a huge stretch....motor mounts and body lift are the two big obstacles that i think those guys ran into, which aren't too bad. If the body styles were the same, all of the wiring and computers should swap from the donor to the half ton.
Old 02-14-2013 | 08:47 AM
maze2525's Avatar
Originally Posted by Chevy_King1500
one of the guys from Danville Performance owns this..
thats mark. he is a BA tuner for the d-max. he also knows his stuff for as in his words "them gassers". he would be the guy to go to if your around indiana if you do this swap
Old 02-14-2013 | 09:00 AM
BGERALD's Avatar
yeah duraburb does really nice work. they have converted escalades and suburbans into LBZ duramax diesels time and time again. they said they charge 20-25k for the diesel swap
Old 02-14-2013 | 09:02 AM
BGERALD's Avatar
RCSB Duramax Build - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
as i said he's building a bagger right now for his buddy's bike show, once thats over with he has to go pick his frame up he had cut and he's putting a Quadrasteer bed on it. man builds badass ****
Old 02-14-2013 | 09:21 AM
Yohns Kustom Fab's Avatar
Formerly classic_speed (2015-06-02)
A few years back there was a guy near Knoxville Tennessee that swapped one into a 90 454SS truck. **** was sweet.
Old 02-14-2013 | 02:19 PM
thunder550's Avatar
Thanks for the link. I'm thinking that a reg cab step side d-max would be sweet
I'm still curious what the fuel mileage would be...DuraBurb said on their 3/4 ton Suburban conversions they see about 10% better mileage, but that's still a heavy truck. How much does a stock RCSS weigh? I'm guessing a half ton reg cab stepside with the diesel would be somewhere around 4500 lb? So almost half the weight of the 7600 lb monster I'm driving right now, which is averaging around 18mpg.
If the increase isn't that much I'd probably be better off building a turbo gasser, but if I could get up into the 30's the diesel would be pretty tempting.
Old 02-14-2013 | 02:27 PM
nonnieselman's Avatar
3.23 gears with the dodomax in a 1500 RCSB, yea that would be sweet!
There was a guy down in LA that had blue or black 1500 with the DODOmax. i rem it was spinning the wheels inside the slicks. it was either blue with black ghost or black with blue ghost flames??
Old 02-14-2013 | 02:32 PM
chevyboy.520's Avatar
This truck is sick
