Anyone done or seen a RCSB D-max conversion?
Old 02-15-2013 | 01:23 AM
  #31
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm getting 21 MPG hwy with just a tune, on crappy winter fuel. ECSB 4x4 HD2500 LB7 with a toolbox full of crap, a heavy Leer old-man canopy, full stereo/sub system, etc.
I think Duraburb only uses a 1 inch body lift at the core support, and tapers it to no body lift at all at the back end. I read about it somewhere a while back. Not 100% positive on the 1" at the front, but they definately do lift only the front, and taper it to the back.
Old 02-15-2013 | 07:48 AM
  #32
thunder550's Avatar
High on diesel fumes
4X4 isn't going to help your mileage...
Yeah more weight and rotating parts, that's ok though.
Yep, it sounds like the only reason for the body lift is to fit the d-max cooling stack in there. Supposedly the Allison fits without the lift.
Old 02-15-2013 | 11:14 AM
  #33
kbracing96's Avatar
Just use a 34" radiator and 4" intercooler like your old truck. It's not like your going to be towing 20k with it! lol.
Old 02-15-2013 | 12:37 PM
  #34
Old 02-15-2013 | 01:31 PM
  #35
thunder550's Avatar
That's what I was thinking...I'd love to use a d-max intercooler if possible, but I think the regular gasser radiator would be sufficient. Not sure if the intercooler, d-max radiator, or both require the body lift.
If I planned on swapping over basically the entire interior (at a minimum, all of the donor truck's electronics and wiring), is there any reason why a 06 LBZ truck couldn't essentially be stuffed into a 99-02 shell?
Old 02-15-2013 | 01:44 PM
  #36
I'm pretty sure you could rig it together with a few minor adjustments.
Old 02-15-2013 | 02:03 PM
  #37
thunder550's Avatar
I think I'm going to start searching for a cheap "host" truck. Once I find that I'll see what I can find in the way of a donor. This should be fun! Muahahaha.
Old 02-15-2013 | 02:23 PM
  #38
thunder550's Avatar
I have a Colorado emissions question here in case any of you know about Colorado emissions requirements:
https://www.performancetrucks.net/fo...ehicle-514284/
Old 02-15-2013 | 10:50 PM
  #39
greasemykey's Avatar
i would love to see a duramax and allison stuffed into a black on black 73 z28
Old 02-17-2013 | 07:45 AM
  #40
sand man's Avatar
30mpg seams hard , if you drop it and got some relaxed gears , 3.42 or 3.23 maybe you could have a chance of getting in the high 20s
