Anyone done or seen a RCSB D-max conversion?
#31
11 Second Hall Moniter
I'm getting 21 MPG hwy with just a tune, on crappy winter fuel. ECSB 4x4 HD2500 LB7 with a toolbox full of crap, a heavy Leer old-man canopy, full stereo/sub system, etc.
I think Duraburb only uses a 1 inch body lift at the core support, and tapers it to no body lift at all at the back end. I read about it somewhere a while back. Not 100% positive on the 1" at the front, but they definately do lift only the front, and taper it to the back.
#32
Yeah more weight and rotating parts, that's ok though.
Yep, it sounds like the only reason for the body lift is to fit the d-max cooling stack in there. Supposedly the Allison fits without the lift.
#35
If I planned on swapping over basically the entire interior (at a minimum, all of the donor truck's electronics and wiring), is there any reason why a 06 LBZ truck couldn't essentially be stuffed into a 99-02 shell?
#38
I have a Colorado emissions question here in case any of you know about Colorado emissions requirements:
https://www.performancetrucks.net/fo...ehicle-514284/
