Anyone done or seen a RCSB D-max conversion?
Old 02-19-2013, 07:43 PM
  #41
High on diesel fumes
thunder550's Avatar
So if I do this, should I do a 2wd or 4wd?
Old 02-19-2013, 08:14 PM
  #42
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Originally Posted by BGERALD
RCSB Duramax Build - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
as i said he's building a bagger right now for his buddy's bike show, once thats over with he has to go pick his frame up he had cut and he's putting a Quadrasteer bed on it. man builds badass ****
You can build a lot of cool stuff when you still live at home
Originally Posted by thunder550
Thanks for the link. I'm thinking that a reg cab step side d-max would be sweet
I'm still curious what the fuel mileage would be...DuraBurb said on their 3/4 ton Suburban conversions they see about 10% better mileage, but that's still a heavy truck. How much does a stock RCSS weigh? I'm guessing a half ton reg cab stepside with the diesel would be somewhere around 4500 lb? So almost half the weight of the 7600 lb monster I'm driving right now, which is averaging around 18mpg.
If the increase isn't that much I'd probably be better off building a turbo gasser, but if I could get up into the 30's the diesel would be pretty tempting.
30mpg might be tough. Ive read of some full size dmaxs getting 26ish driving slow and a lot of tuning. Either way it ought to be fun and definitely go 4wd. 2wd dmaxs are just good for a smokeshow.
Old 02-23-2013, 01:39 AM
  #43
11 Second Hall Moniter
AKlowriderZ71's Avatar
Here's a decent deal on your drivetrain....
FS: LB7 Motor, Transmission, transfer case - Duramax Diesels Forum
Chewy07
11-14-2015 09:46 PM
Silver8ado
09-30-2015 11:42 AM
MikeD.
09-17-2015 09:39 PM
spooneralmighty
09-11-2015 02:28 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Anyone done or seen a RCSB D-max conversion?
