Anyone installed a factory E fan harness?
I just got from E bay what is supposed to be a factory e fan harness part # 15912581. Part # on harness is 10385842. Does the factory e fan harness come with all headlight, parking, etc. connectors. Also does anyone know if these part #'s sub to each other? Thanks for ant info.
I used the factory harness. It does come with all of the lighting harness included. You have to seperate the Efan harness out of it. The below link is where I posted some info about it before.
https://www.performancetrucks.net/fo...88#post3626288
For anyone that has any of these part #'s 15143073, 15117813, 15112489, 10385842, 15216055, 15836325, and 15912581 it appears they are incorrect, maybe they fit LS1 fans? they do not fit 05 up factory fans! Connector for fans is incorrect or not there. Only the last 2 part #'s appear to be available. Again my dealers info. What I found looking into using a factory E fan harness, here goes. I would buy from www.gmpartsdirect.com and have been told to remove E fan harness from this harness. This is the cheapest harness I found, there may be a cheaper one just trying to help. What appears to be the correct part # 15216042 subs to 15912597 but cost is $137.54 again all prices from gm partsdirect.com, and all subs from my dealer. Hope this helps. For me spending $137.54 and getting factory harness works out better for me. I have a little more money than time at this point in my life. For those with more time than money making one is not a bad exercise. Good luck to all.
mr03silverado
07-17-2015 02:15 PM
