Anyone know the ARP crank bolt TQ spec?
Baltimore Whore
I reused the same bolt, red lock tight, impacted it, then put a 2ft bar on it with a small cheater.. Fine no probs what so ever.. The pulley is more less pressed on.. The bolt holds it from walking off..
Tin Foil Hat Wearin' Fool
1) half inch ratchet with my jack handle on it and put my 160# *** on it bounce it a bit
2) hit it with the impact til the pulley bottoms out and hit it a couple more seconds
Use a little dab of red loctite in either method for both stock and ARP bolts, never had a problem in all the ones I've done.
slowlsx
08-10-2015 05:33 PM
