Anyone make 500rwhp with a roots or twin screw charger on a truck??
#32
single digit dreamer
Originally Posted by moregrip
thanks man, i see you are very excited about it on that thread. i will probably get bashed for being negative about the radix actualy having a max hp limit but i dont see a chart or anything. i am a little doubtfull that those numbers were correct. if the truck is bouncing around on the dyno you are going to see some spikes. at this point i dont think the radix has been proven to more than a few hp over 500 and i dont feel it is right telling people it is good for 600+.
disclamer!!! i think the radix is the best blower on the market and a kick *** set up but it does have a limit just like anything.
#33
what a rush!
Just in this thread you saw a 540rwhp @ 8lbs.
lol, yes, I am still very excited about that!
#34
Former Moderator :(
Originally Posted by OBXMarine
How about some more info on those big ol' headers please.
but they sure did fit nice and dual 3" cats into a dual 3" in and a single 5" out merge collector and a 5" in and a 4" out Flowmaster with a big chrome 4" tip
I call it the million dollar exhaust.
#35
I take most things I read on the Internet with some skepticism, when I see a couple of people hit a number then I believe it. Especially when it is posted about with some hard data like dyno sheets and I have seen them work the truck from stock up to where it is now.
What I see with the radix is people having great results in the 400-500hp range but as soon as they try to push it above this point it just seems to run out of steam. 500hp is a lot of hp and will make most people very happy.
#36
Former Moderator :(
with a 90mm T Body and no MAF the radix is good for 700 flywheel. The biggest problem is that it is a draw through system and the stock MAF is pulling almost 2.5-3" of vacume at 550-600 flywheel and that brings the temps way up and makes it fall over. I have seen a 35 flywheel hp gain on a radix with the 80mm t body over stock. Remember this is not a blow through system like a Vortech so you have to treat your intake as it were a N/A engine
#37
what a rush!
When you start getting in the 500-600+rwhp range, selection of components becomes more critical, in other words, many supporting elements start to reach there limit, furthermore, any modifications need to be thought of as a complete system, or, how they effect said system; starting at the airfilter, working all the way back to the tailpipe
#38
Originally Posted by ranwalk
I havent been able to find any information on the Kenne Bell intercooled system. Just that small pic on thier website. Where did you see it?
I saw the pic on their website and called them for an update, plus also heard the they busted their 4L60 after a 500hp dyno trial.
#40
11 Second Truck Club
I made 489 last time on the rollers. If I had uncorked it there is no doubt I would have been over 500. That was with the stock crate motor with nothing but a cam. Soon I will be up and running again with a 30 over 6 liter with a little bigger cam and some ported heads, hopefully I can make 550 or so.
