Anyone put a corvette exhaust on a truck?
H-pipe X-pipe LMNOP-pipe
It doesn't matter. The critical elements are the distance from the header/exhaust manifold to the tips and the pipe path (bends..location and number) It is pure physics. Sound travels in waves and bounces off the inner walls of the pipes and we hear those waves as sound. Pulses are generated as the cylinders fire (firing sequence/timing will also influence sound). When the pipes are the same length and shape, that makes the best music. Crossover pipes (X and H) help to balance the system without adding too much interference.
I think another thing that gives the vetter their sound is that the mufflers are right at the back and your hearing the exhaust just as it comes out the muffler I think it all plays a part in it
That woulld be so siq
Guys,
The corvette exhaust systems wont fit into a truck, but the key to the sound is the exhaust setup.
My corvette (99 Coupe) is stock manifolds back, to a magnaflow magnapack (X piped) system, in my truck, im using a very similar system, LT headers, back to a H pipe, then magnaflow bullet mufflers, and out. Ive cammed my truck, but the only thing im lacking from the corvette setup is the 10:1 compression.
When i finish it ill upload a link of the sound of my truck running beside my corvette so you guys can hear the difference in sound
