anyone running these?
https://www.patriot-performance.com/...9&cat=0&page=2
thinking about a set for my truck within the next year, are they worth the money or should a get a set of 706s have them P&Pd and milled?
those valves are way too big for your 5.3
I've read way too many so-so things about Patriot so I stayed away from them. I went with PRC 317s myself.
What I would do personally is buy the PRC stage 2.5 5.3s from TSP and have them milled to 59cc that will bring your compression up on your 5.3. Now, in the longrun if you plan a 6.0 swap, the PRC 5.3's would work beautifully with the LQ4 (but not LQ9 which is what I have and really limited my head options because the starting compression is already pretty high). Now granted, to get the same compression as you have now with your 5.3, when you swap the heads over to the 6.0 the compression will be about 11:1. You will have to run 93 all the time. Hopefully that isn't a problem.
The beauty of the PRC 5.3s over the LS6/317 heads is the fact that the 5.3s flow the same as LS6 heads but they have a smaller runner. This means higher air velocities and better throttle response. This is the exact principle that makes the AFR 205cc heads so sought after.
hope that helps
hope that helps
that does help. are these the heads you are talking about? and what is the combustion chamber size on them? all i see is "Smaller Combustion Chambers For 10.75:1 Compression"
http://www.texas-speed.com/shop/item.asp?itemid=84
i have no problem running 93 since i already do all of the time (because of timing in the tune)
