Anyone tried running their engine while the tranny was out?
Old 04-25-2006, 02:31 PM
High on diesel fumes
thunder550's Avatar
Cool. Thanks all.
Old 04-25-2006, 04:24 PM
5.3 racer's Avatar
you'll need a jumper for the park neutral switch, otherwise the starter won't crank.
Old 04-25-2006, 04:25 PM
thunder550's Avatar
Hmm good point. Where do I jumper it?
Old 04-25-2006, 04:46 PM
How do I change this text
Wilde Racing's Avatar
Do you pull the PNP (park/nutral position) sensor off the trans, or did you get two plugs that are glued in unpluged?
Old 04-25-2006, 04:53 PM
thunder550's Avatar
I pulled the whole thing off. Plugs are still connected.
Old 04-25-2006, 04:57 PM
thunder550's Avatar
I should be ok then huh, as long as the sensor hasn't moved to a different position.
Old 04-25-2006, 04:59 PM
Just line up the tabs on the switch with the notch on the switch body. That is neutral.
stealthperf
34
02-14-2016 11:35 AM
Noah Burns
09-07-2015 05:50 PM
Mossyoakglock
07-17-2015 08:30 AM
Chiphead
07-13-2015 10:16 PM
Mzay
07-06-2015 11:03 PM
Quick Reply: Anyone tried running their engine while the tranny was out?
