ARH/possible kooks header-----------noise?
Here is the other dealeo.As i driver all i hear is the drivers side .I have no idea what the Pass side sounds like,I need to ride shotgun,if that side has ping bounce I know its the headers and the cab.both side headers doing there thing.there thing is being noisy.
does wrapping cut that noise? cuz i will be doing it asap
I have kooks on my g8. I can't hear them in the car. But standing outside, the tick is noticeable. Prob a little less then the pacesetters on my silverado.
If its all slip fit, did you wrap the joints with tin foil?
I wouldn't wrap them. Always cause rust or the coating to flake on them.
Also, I've never seen an aftermarket gasket out perform oem ones.
Is it possibly that this noise is louder than you are used to because of the larger piping and thinner stainless material? The tick I got from my ARH was slightly more than others I have heard on these trucks.
It's so hard to tell if there is an issue through the computer like this... everyone has a different level of what they find intrusive. I know when I first put my headers on i swore up and down there was a leak and I was in the same boat... it wasnt my first header install. I took a couple things off and used high temp RTV around the connections and it may have helped a little but they still have a decent tick to them.
Gmc_sierra
09-13-2015 10:02 PM
