ARP crank bolt seeping oil
Installed an ARP crank bolt in wifes 5.3 a few years ago and it has had a seep leak since the day I put it back together I followed the instructions and used their thread lube per the instructions.
Do any of you have a preferred method for sealing it up that works cause following their instructions makes for an oil leak. The stock bolt has a locking compound for sealing it on the threads and on the flat against the harmonic balancer. I can kick myself in *** now after having an oil leak for the last couple years because as I was following their instructions I felt like green locktite would have been the better option if it wasn't going to leak.
I have an ARP crank bolt in my 6.0 with no issues.
I have an extra stock one around somewhere if you would like it?
Did you use their lube on the threads and the flat washer or a threadlocker/sealant.
I know it's torqued correctly I used the flywheel holding tool and my diesel torque wrench so the torque wrench was not at the edge of maxed out. Seeing as a maxed out torque wrench could give a false reading.
I appreciate the offer on the bolt I'm going to try and do cam swap next weekend and see if during disassembly I can tell exact location it's coming thru at the bolt once I pull it out. For sure it's coming out from under the bolt head washer area.
shakenfake (07-12-2024)
Their lube and the flat washer.
shakenfake (07-13-2024)
arthursc2 (07-15-2024)
Maybe I did use sealant but I’m 95% sure I just did per their instructions
2500HDKartRacer
09-02-2012 06:38 PM
