arp head studs worth it?
just wonder if I should put the arp heads studs on my new set up or just stick with stock gm bolts? my set up consist of a 6.0 lq9 with a 230/236 .591/601 on a 110 lsa, patriot stage 2 ls6 heads 64cc chambers., and all the goodies to go with it.
I went with new GM bolts when I swapped heads. I was told that the ARPs need to be retorqued after the first heatcycle. I didn't feel like taking the exhaust off to do that. The GM bolts are TTY, they will work fine for N/A. If you where FI then I would look into the ARP.
Originally Posted by Dark Halo
I have a set of oem bolts that came with my heads
it could be a week or 2 before I can get as I just bought a new raditor and altanator
Thanks
Justin
The ARP studs have more clamping force than head bolts and are really nice to have on motors that use a power adder{FI or nitrous}to keep the heads from lifting.If you are planning to spay the motor the ARP stud are definately worth the money.
