ASM Install
Originally Posted by L-EATER
Somebody needs to fill you in on the busted knuckles, all the cursing thats gonna take place, and the 8 hours you are about to spend. The first time is an absolute SOB. Some people on here will agree and some say they went on with no probs. I guess it is just production tolerances, but some sets evidently fit better than others. I hope you get some good ones, otherwise have plenty of beer on hand....
You gotta give a little blood sometime
Your goimg to need a muffler shop anyway to weld 'em up cats or not. Some shops will do the install. Ask around, it's worth a couple of hundred $ easy.
The shop I spoke with said they would install them for 225.00. I figured it would be worth it. Drop it off, go to work, and pick it up later makes it a little less expensive.
Hey, hate to start this thread back up and all. But I had a similar situation with the ASM's. Sponser here pushing the Dynatechs, not hard, but was saying that there is a lot of modification to be done to fit the ASM's. I am planning on buying these from TByrne with his 10% off, and just wanting to know what all needed to be done. I too, am planning on having them installed, I was going to have the sponser install them.
Someone mentioned having to unplug the 02's, you don't have to remove them altogether do ya?
Yes that little bitty stud is such a pain. For the driver's side I disconnected the steering shaft and installed it from the bottom. The passenger side has to go in from up top thru all the AC and heater hoses and it is a much bigger header and a much smaller space so be prepared to cuss a lot. Also mine burned a starter wire so you may need to loosen and turn that starter wire where it is not against the starter heat shield. You will know what I mean when you see it.
