ASP pulley question
Re: ASP pulley question
i purchased the asp pulleys and it came with the one for the alternator to. if the one for the alternator is bigger than the one that it has will it hurt my amperage or will it give me more charge? i am running electric fans and good sound system.
I have the smaller one and it squeals bad as well as shreads a nice plactic dust from the belt. I have sent it back once only to get another that does the same thing. There was another board member that purchased a set for his 5.3 and had the same problem. I'm running e fans and a small system 2 amps. I don't seem to have any problem with the stock pulley.
Lar
Lar
ArticGMC, I had the same problem. Got a fix also........you need a smaller belt than what ASP says. I am not sure what size it is exactly, but try going 3/4 inch smaller than what ASP says.
wrb002
08-25-2015 03:56 PM
