Attn..Yelo ABS pump and Circuitsolutions??
Originally Posted by Ryan23silverado
Oh ya if anyone has to do this job, it is really easy to take off that EBCM module.
I just took the ebcm off the abs pump. I had a torx screwdriver set that was just the ends that you would insert into the tip of the torx screwdriver. I don't know if that was too clear, but like the little phillips or flathead adapters that you use to put into a drill...only I have a torx set.
Being that I just used that 1" tall torx adapter, I could clear the top of the floorboard no problem and just use an open end wrench to turn the adapter.
Originally Posted by Yelo
Well..I kinda-sorta repaired mine.....I put black tape over the lights (I almost perfer it without ABS actually)
Just got my EBCM back from "Gavin Curtis" <gavin@circuitsolutions.info>. Very fast turn around, I shipped UPS 2 day air there and back. He got last Wed. and sent out Friday.
Put it on and everything back to normal. He is very professional and easy to contact. Retunes the EBCM with instruction and a receipt of payment for your records.
rednekferlife101
09-14-2015 05:27 PM
