Attn..Yelo ABS pump and Circuitsolutions??
Old 08-06-2004 | 09:33 AM
whitez71's Avatar
Originally Posted by Ryan23silverado
Oh ya if anyone has to do this job, it is really easy to take off that EBCM module.
Did you get the EBCM module off with out have the remove the ABS modualator from the truck? Or did you take them both off as one piece then seperate them??
Old 08-06-2004 | 03:49 PM
Ryan23silverado's Avatar
I just took the ebcm off the abs pump. I had a torx screwdriver set that was just the ends that you would insert into the tip of the torx screwdriver. I don't know if that was too clear, but like the little phillips or flathead adapters that you use to put into a drill...only I have a torx set.
Being that I just used that 1" tall torx adapter, I could clear the top of the floorboard no problem and just use an open end wrench to turn the adapter.
Old 08-06-2004 | 04:28 PM
MacADaYear's Avatar
Originally Posted by Yelo
Well..I kinda-sorta repaired mine.....I put black tape over the lights (I almost perfer it without ABS actually)
I did too untill I had to slam on the breaks when this dumb chick cut me off on the freeway. Thats when you will really appreciate your ABS system.
Old 08-07-2004 | 03:50 AM
Mac is right. I locked it once and you might as well be on ice it feels like!
Old 09-01-2004 | 09:56 AM
ls1z4me's Avatar
Just got my EBCM back from "Gavin Curtis" <gavin@circuitsolutions.info>. Very fast turn around, I shipped UPS 2 day air there and back. He got last Wed. and sent out Friday.
Put it on and everything back to normal. He is very professional and easy to contact. Retunes the EBCM with instruction and a receipt of payment for your records.
Old 09-01-2004 | 12:06 PM
Yelo's Avatar
well....maybe I *should* get this thing repaired after all, I'm just too lazy to crawl under my truck when it's 120º outside so I'll do it when it starts to cool down here in October
Chavette
10-28-2015 07:33 PM
silver-mod-o
09-19-2015 08:46 PM
chopperloco
09-18-2015 06:44 PM
rednekferlife101
09-14-2015 05:27 PM
03chevytruck
09-10-2015 10:18 PM
Quick Reply: Attn..Yelo ABS pump and Circuitsolutions??
