AWD 4l60e same as 4x4 4l60e?
Old 03-16-2004 | 11:57 AM
jamesjones's Avatar
Default AWD 4l60e same as 4x4 4l60e?
Is the Escalade AWD 4l60e the same as a 4x4 4l60e? I found a 6.0 engine and trans out of a 2003 Escalade but I'm dropping it into a 4x4 so I need the 4x4 output shaft. Anybody happen to know about the AWD 4l60e? Any info is much appreciated.
Thanks
James
Old 03-16-2004 | 12:03 PM
Scream's Avatar
MOOBIES Moderator
If it's the LQ9 Escalade motor, it should have a 4L65E hooked up to it. I'm not sure what differences there might be between 4/AWD. Sorry.
Old 03-16-2004 | 12:17 PM
BigTex's Avatar
Will bolt right up and work like a charm. I ran the 4L65E out of an Escalade in my Z71 last year. No problems.
Old 03-16-2004 | 12:19 PM
Don't worry the difference is in the inside, the outside is the same
Old 03-16-2004 | 12:26 PM
jamesjones's Avatar
Sweet. Hopefully this will be going in my 72 K5 Blazer. Now I just need to find a shop to do the swap for me. Can you guys recommend anyone in SoCal?
Old 03-17-2004 | 04:14 AM
Are you planning on using a gen III motor as well? What t-case are you planning on using?
Its gonna take a lot of work to drop it in that truck.
Sorry I cant really help you out on finding a shop, but there are a lot of guys in this area so im sure someone will be able to help
Old 03-17-2004 | 03:20 PM
jamesjones's Avatar
I'm going to be using the 6.0/4L65E combo out of an Escalade. I'll be keeping the NP205 Tcase. I believe the Advance Adapters 4L60E/NP205 adapter will still work for the 4L65E as it was stated before that the 65E and 60E had the same externals just different internals. Any help is much appreciated.
Old 03-18-2004 | 05:41 AM
I didnt know they made an adapter for the newer 6 bolt trannies, but they do.
Also even if the output shafts are different, It doesnt matter because you are gonna replace the output shaft anyways. Their kit uses a replacement output shaft that is a little shorter to make it all fit right. Depending on what 205 you have you will need a few other parts as well.
Sounds like a fun project.
If you have any other questions let me know. Im pretty familiar with the setup you have
Old 03-18-2004 | 01:18 PM
jamesjones's Avatar
Thanks for the info. I have the stock 1972 NP205. Yeah it's going to be one heck of a project, way beyond me. That's why I'm going with a shop to do the swap. A lot of people ask why I'm doing it. I planned on installing an OD transmission and Fuel Injection and building a motor that would put 450 to the flywheel anyway. When you add up the cost of doing that to the old style engine it'll be pretty close to what I'm going to have in this swap. I might as well get the more efficient motor and trans. Plus the cool factor of doing something that to my knowledge hasn't been done before.
Old 03-18-2004 | 01:42 PM
grooves12's Avatar
You might want to check out the Conversions & Hybrids section of this board. You will find LOTS of useful infotmation pertinant to a project like this.
