bad problems need help
i have a problem that i can not figure out tryed everything i know every time i spray my nitrous there is a loud pop then it dies its like the motor just quits some times i can run a full run with out it then the next run it might do it from the start or maybe half way through i tryed every thing checked everything i thought it was spark plugs changed them they looked good put new ones in any way does the same thing dont know what to do very frustrated every thing else is great even runs good on motor please help to my 5.3
Do you have any data logging program like Autotap or Efilive that you can look at when it does this? You might try posting this in the Nitrous section above the Truck section. They might have a solution if no one here does. Good luck man.
Tydriver
45
10-23-2015 09:19 PM
