Bad Speedo or VSS?
Old 01-27-2007 | 12:34 PM
SmOkA2k3's Avatar
Default Bad Speedo or VSS?
My spedometer does not move smoothly. It moves more like the second hand on a clock and if i spin the tires it will go up around 35 and act like thats 0. It will say im doing 75 when im doing 40 or so and only resets itself back to zero after turning the truck on and off several times any feedback would be helpful.
Do I just need a new Speedo (would be getting an Escy Cluster if so, or is there somin wrong with my vehichle speed sensor)
On another note if i get an Escy cluster will the trany temp gauge work or does it have to be tuned in or hardware added to my 60e?
Old 01-27-2007 | 02:16 PM
Country Boy's Avatar
Senior Member
I had your same problem. The VSS will throw a code, also an easy way to check is to see if your odometer is still working. If it is, its the cluster. Mine speedo motor in the cluster died so I replaced it with a 06 SS one. The tranny guage will work as soon as you plug the new cluster in. Why they didnt put it in the 1500s is a mystery...
Old 01-27-2007 | 03:59 PM
CNE's Avatar
CNE
Bad cluster. The motor that drives the speedo needle is bad. Common problem, I see at least one a week at the dealer.
Old 01-27-2007 | 04:12 PM
budhayes3's Avatar
PT's Slowest Truck
Just to help re-enforce what the others have said, I've read alot about the 03's having cluster issues...
Old 01-27-2007 | 09:06 PM
moes04silverado's Avatar
my 04 has had 2 clusters.....
Old 01-27-2007 | 10:32 PM
lady3bglover's Avatar
I had a bad cluster in mine, had it replace already.
Lady Glover
RustyD
05-23-2016 07:04 PM
00loudchevy
12-03-2015 05:54 PM
dsbodley
11-14-2015 09:46 PM
lukn4trbl355
10-21-2015 11:19 PM
Jr. SXT
09-30-2015 07:23 PM
Quick Reply: Bad Speedo or VSS?
