basic wire up for fans
i've been wanting to put electric fans on my truck, but keep getting told i need a relay? well i can care less if the fans turn on by themself. i mean i want to be able to just wire them up to a toggle switch and have them on when "i" flip the switch. Can't i just wire them up to a toggle switch as if they were fog lamps? Also how can i get off the factory fan without using the fan tool? seems no one here in this town has what i'm requiring.
Sure, but it will be a lot of amps without a relay. A simple temp probe or harness might be better/easier in the long run.
Use a big wrench and a hammer to get the clutch fan off. A pipe wrench or adjustable works. I ended up using a 18inch cheapie adjustable one from harbor freight and a fist maul.
Use the search function on the forum. I'm sure there's a few write-ups with pictures just in the gm engine/exhaust section.
Alvin@PCMofNC
09-03-2015 06:38 AM
