battery or starter?
Old 12-18-2003 | 11:27 AM
onyx's Avatar
14 Second Truck Club
Default battery or starter?
the truck has no problem starting cold, as in, its been sitting all night... sometimes.
if i try to start it again after, say, i went into the store and came back out, it takes like 3 times, everytime to get it started again. whats up with this?...
Old 12-18-2003 | 11:49 AM
whitez71's Avatar
More description would help. Does it turn over or not crank etc...
Old 12-18-2003 | 01:18 PM
onyx's Avatar
it cranks, but no turn over....thats what i meant by each time... sorry.
Old 12-18-2003 | 01:41 PM
BigKID's Avatar
If it acually turns the motor over but does not crank.. I would look more into a fuel or ignition problem. When was the last time you changed you fuel filter?
Old 12-18-2003 | 01:45 PM
whitez71's Avatar
Also is it cranking at the regular speed or slow. If normal speed sounds like it is fuel related. Maybe the PCM is not sending the correct fuel mixture because it is thinking the engine is cold when it is warm. Could be a flakey coolant temp sensor??
Old 12-18-2003 | 01:50 PM
BlownChevy's Avatar
blownerator
Replace the fuel pressure regulator!
Old 12-18-2003 | 01:55 PM
onyx's Avatar
fuel filter got changed about 6k ago.... its been doing it ever since i bought it used. i was thinking maybe started was hanging up...
it cranks regular....
Old 12-18-2003 | 02:02 PM
BlownChevy's Avatar
blownerator
if it cranks/turns over regular but does not start, I would check the Fuel Pressure regulator.
Old 12-18-2003 | 03:11 PM
onyx's Avatar
okey... this would be....... where?... near the pump i suppose?
Old 12-18-2003 | 03:22 PM
BlownChevy's Avatar
blownerator
Driver side fuel rail under the hood. Gold in color round in shape with a vacume hose running too it.
Quick Reply: battery or starter?
