before and after TBSS INTAKE dyno finally
#123
I think you would need injector spacer's to do that because the TBSS intake comes with LS2 style, taller injectors than our trucks have. You would have to drill some on the rails to make the mounting points line up with the intake. Also, you would have to weld on A/N fittings to each rail and run a crossover hose because the crossover on our rails isn't tall enough to clear the intake. IMO, I would get an intake that comes with rails and injectors. For your app, the injectors should flow plenty. You would only have to change the injector pigtails to match the LS2 injectors, I believe they have an EV6 connector. That would make for a much simpler install
#124
Your current fuel rail isn't wide enough from side to side. Use the fuel rail that the intake comes with
Get the truck 87 or the car 90mm TB
Get the Dr. X harness adapter for the TB
The EVap switch needs to be from the same year intake, your current EVap will not work, but it is the same electrical plug
the MAP sensor harness does not need to be cut or extended
---->>> BTW: I have an intake setup for sale in the for sale section <<<---- click it !
