before and after TBSS INTAKE dyno finally
Old 01-20-2010, 11:08 PM
  #31
dlt76028's Avatar
^^^ what did you do for a FPR?
Old 01-20-2010, 11:46 PM
  #32
007gmc's Avatar
Originally Posted by KLUG'S SS
Either way good numbers and a conversion that I have seriously considered and have thought about quite a bit for my LQ9.
Have you been back to the track since the swap to compare times? Just curious.
i wish our track closed for good
Old 01-21-2010, 01:45 PM
  #33
truckmann's Avatar
The corvette fuel filter is regulated to 58 psi.
Old 01-23-2010, 10:17 AM
  #34
low2001gmc's Avatar
wow nice numbers but a lil hassle.....
Old 02-15-2010, 11:34 AM
  #35
low2001gmc's Avatar
Nice gains. With only a tr224 cam in my single cab, i didnt figure a swap to a fast would be worth the expense. For a fast 90, I would need to replace or relocate some parts (more of a hassle) and for a fast 102 i felt i needed more cam, etc. This TBSS intake swap post impressed me enough. I placed it on my wish list and when I commented to my mechanic I was looking for one, he walked me over to a side of the garage and said like this one...yeah I got me one that quick and he is putting a fast 90 cable driven tb for my truck with 36 lb injectors. should work great...cant wait.
Old 02-15-2010, 11:54 AM
  #36
Darkblue5.3's Avatar
im also running the TBSS intake from an 06 TBSS with the rails/ev6 connectors and have the ls2 fuel injectors/ 90mm on my 5.3L
there was a thread i read a while back that the NBS and the TBSS intakes are indeed NOT the same, i will try and look for it and post it... it states that the TBSS are a tad wider/larger than the NBS intakes, but are quite similar....
i talked to a guy a while back who actually ports these intakes and "plastic welds" them back together, naming it "frankenstein" could use for N20 but not recommended for FI...its a shame i lost his #...it was like $600 for a port match of the intake and the TB. heres a pic of his work.
Old 02-16-2010, 07:03 AM
  #37
low2001gmc's Avatar
Say dark blue nice numbers for a 5.3.....
Old 02-18-2010, 08:08 PM
  #38
CHarris's Avatar
That would be me... I do them a little different now, though. The top comes off in one piece and I think we're good to go on FI now. It's a lot more than a port match going on inside
Old 02-22-2010, 10:20 PM
  #39
dlt76028's Avatar
Originally Posted by truckmann
Not true. I'm using the regular 8.1L injectors on my TBSS intake with the TBSS rail and they are the same size. I have the TBSS injectors but didn't want to have to change the connectors.
I used the TBSS fuel rails and a corvette fuel filter to deal with the return and fpr since I didn't know where to buy or want to make a new crossover.
So according to you, all you need is a intake, rails, and a vette fuel filter and the truck injectors work fine? What about sensors? Do you just swap them over from your old intake?
Old 03-02-2010, 11:26 PM
  #40
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Bump for the questions above.
Quick Reply: before and after TBSS INTAKE dyno finally
