Belt/pulley squeal that won't go away!
1 Post
This started about 2 weeks ago when it started to really get cold here (oklahoma).. Had some small belt squeal issues before but a bit of tire shine or bar soap on the belt made it go away for months. Sometimes it squeals on me, other times it doesn't make a sound. Sometimes it only squeals when the engine is under load and gets quieter as I cruise or it idles. I've replaced belts, tensioner, idler pulley, and swapped alternators with another I had laying around. Nothing has fixed it. I can start the truck without a belt and there is no squeal. I have two different belts i'm using and it squeals with both of them on there. Last night, it threw the belt under a WOT pass at about 5500 rpm in second gear.
Only other thing I can think of is to pull the water pump pulley and put it back on to make sure its aligned right but it looks like there is a special tool needed.
I'm about to just set the truck on fire and drive it off a cliff I'm sure its something small that i'm missing, but I CANNOT find it.
1 Post
[QUOTE=TIM Z;5054192]After reading you've about changed everything but the water pump and balancer , I'd think your water pump is the culprit.[/QOUTE]
I can touch a bar of soap to the ribs of the belt and the squeal goes away instantly for a little bit.
1 Post
running a straight edge off the crank pulley, everything is flush except the P/S pump. its about 5mm out from the crank pulley. The lip on the front of the P/S pulley looks a little thicker than the rest of the pulley's though..
