Belt/pulley squeal that won't go away!
Yes, you need a pulley install/ Removal tool made for the power steering pulley. Straight edge across the power steering pulley and see what the gap is between the straight edge and the face of the crank pulley. It doesn't take much for the belt to make noise, I dealt with this when I went 8 rib initially when setting everything up.
you can rent the p/s pulley tool from any auto parts store for free. otherwise they are only $30 or so and easy to use.
after you get the p/s pulley aligned, thoroughly clean all the pulley's with brake cleaner and install a NEW belt. This will solve your noise issue.
