benefits of ls6 intake on our trucks.
#21
Originally Posted by Scream
I'm curious to see some more results with the LS2 intake. I wonder if you could use the Multec II injectors, 97-98 Corvette rails/crossover, and an LS2 intake on a truck.
Well, an 04 or 05 truck with the returnless system could run the LS2 fuel rail.
#23
Originally Posted by GoldenVelvet
General thinking would tell you that the LS2 is going to breath deeper then the LS6. But the problem is you would need to have a motor with a set of lungs to take advantage of it. Big cubes, high output, or boost to take full advantage of it.
Besides the better flowing intake of the LS2, here is another payoff for those of us willing to give it a try:
#24
Originally Posted by XLR8NSS
Yelo - I wasn't bashing what you said or anything so please don't take it that way. I only say that because I thought I heard a hint of disgust in your reply.
#25
Hey....that's about how the LS1 manifold looks on my truck , now do y'all understand why I am loath to take pictures of it....
Originally Posted by BigTex
You could get the truck rails and injectors mounted, but its an ugly beast when complete:
#27
I haven't posted much on my set up since I'm still working on a couple of things. I'm running the 90mm FAST intake on my 427 and can definitely feel a difference from the truck intake. Granted, I actually need all the air I can get. With the truck intake, my power would start to drop off at about 5200 RPM's. With the FAST, my power doesn't drop off. I shift at 6300 RPM's. Also, my 60ft's are down from 1.82's to consistent 1.75's. These times should improve when I resolve my lifter issues that I'm having. Once I get everything done (in about 2 weeks) I'll do my best to get some pics of the setup and try to answer questions about the swap.
#29
Scream - Yes you can. I had a couple of ideas. One is to take the existing truck crossover and cut each side off just before the first bends. Then braze on some smooth 90* elbows and connect each side with fuel hose. Could be done with AN fittings and braded line if desired. You'd still have the bulky rails though.
I think a better look would be using the 97 C5 rail I have, cutting the crossover tube at the sides so the injectors will seat fully. Then use black fuel hose to connect them. Then it would have a clean factory look and proper low profile side rails.
Custom billet side rails could be used with an aftermarket fuel pressure regulator to feed the return line. More expensive, but very cool.
#30
Comp Cam xr265hr
0.522/0.529 inch intake exhaust, 212deg intake/218deg exhaust, 114deg lob displacement
Truck intake= HP/TQ, 429/422 @5900/5000rpms
LS1 intake= HP/TQ, 450/439 @5900/5000rpms
LS6 intake= HP/TQ, 459/447 @5800/5000rpms
FAST intake= HP/TQ, 462/450 @5900/5000rpms
My 220/220 112 definitely had more up top... but unfortunately I didn't scan any power output at the time. I can't say for sure if it was cam specs vs cam specs that caused it... or if it's possibly an intake design thing.
I'll be picking up a LS6 or a used LSX over the winter... I'm planning on running LS1 heads too - so I wanted a proven/matched setup. I'd ideally like to do the swap all at once, but I also like to feel results from individual mods. Maybe I'll build the intake and get it on before-hand.
